Read from memory
The address is right there in PD from 0x0 to 0xfff.
- Yassine-Ca1 year ago
When I execute tcl scripts, I get these errors:
Error: Failed to read data from FPGA memory. Result: ERROR: JTAG communication error is detected. It can be caused by the hardware failure and signal integrity in the JTAG chain. Try to restart.
while executing
"error "Error: Failed to read data from FPGA memory. Result: $result""
invoked from within
"if {$data_from_fpga == ""} {
} else {
puts "Debug: Data read from FPGA at..."
(file "receive_altera_FPGA.tcl" line 72)
------------------------------------------------Error: Error executing TCL script:
Error: Failed to read data from FPGA memory. Result: ERROR: JTAG communication error is detected. It can be caused by the hardware failure and signal integrity in the JTAG chain. Try to restart.while executing
invoked from within
} else {
Note that when I execute the script, I see that RX and TX LEDs inside FPGA near JTAG are flashing.Please find attached the tcl file in text format.
I have created tcl file, but I need to execute both of the commands quartus_stp and quartus_sh in the same file.
I use read_content_from_memory which is quartus_stp instruction, but I need to execute commands inside the same file relative to quartus_sh, if any solution with two files that 1 execute from other?
Regards.
Yes, Because I modified the design from JTAG to JTAG Bridge.
I'm trying to see if any communication can be done, and let you know.
Regards.
