Read from memory
it's unclear which interface logic you are using to read from memory. There can be a JTAG controlled debug master (JTAG to Avalon Host Bridge) as well as custom logic connecting second memory port through conduit. Would be helpful to see a block diagram of your design.
Frank
I maked a mistake using non JTAG Master, now I use it, please find image attached.
These the code generated by Platform Designer:
module mem (
input wire clk_in_clk, // clk_in.clk
input wire memory_clk2_clk, // memory_clk2.clk
input wire memory_reset2_reset, // memory_reset2.reset
input wire memory_reset2_reset_req, // .reset_req
input wire [11:0] memory_s2_address, // memory_s2.address
input wire memory_s2_chipselect, // .chipselect
input wire memory_s2_clken, // .clken
input wire memory_s2_write, // .write
output wire [7:0] memory_s2_readdata, // .readdata
input wire [7:0] memory_s2_writedata, // .writedata
input wire reset_in_reset_n // reset_in.reset_n
I could connect into the DE1 board over the tcl, but I had the problem to continue, can you assist me in the tcl code attached.
Regards.
