hii i am working on it thanks:)
May I know if you have any update on this?
- aiedb5 days ago
hii good morning , i found out something that got under my radar sort of speak , i built a qsys system with pll that feeds the on chip flash ip and the dual configuration ip , and my logic for reading and writing worked directly from the on board osc , so infact even if the clk is 50mhz the same .
the outputs from the pll and 50mhz from osc ,they are separate time domains i removed the pll from the design and worked with the on board osc clk only for my logic and for the altera ip and it worked i dont have any failures any more , i still need to test the design with reduced delay between the sent rpd words . i will check on that
- JohnT_Altera1 day ago
Thanks for update and glad that you are able move forward after resolving the issue
- aiedb1 day ago
thanks for your help :)
