Hi @minjoolee
Have you Generate the Simulator Setup Script in the document section 2.5.3.2.1. ?
Intel Quartus Prime Pro Edition User Guide: Third-party Simulation
Tools > Generate Simulator Setup Script for IP
The script should be in vcs_setup.sh or vcsmx_setup.sh files generated in your project directory.
Please go through Section 2 Intel FPGA Simulation Basics first to understand the simulation flow before go to section 4.
Richard Tan
HI , this is my answer
--> YES
SEE second screen shots
1) scripts result are not same as
2) Without ignore comments in script,
cmd> source vcs_setup.sh
should be working. but not.
3) Can I get simple example such as only 1 PLL design for VCS RTL simulation .
to see waveform ( generated FSDB )
