You may search for other example designs, for instance, “simple socket server” at the link below as the starting point.
https://fpgacloud.intel.com/devstore/platform/
Regards -SK
I can't find any examples for the Arria V GX board. Do you have a suggestion for which board to look at it?
I went through the Using Triple-Speed Ethernet Tutorial IP for DE2-115 Boards today. I modified it to work with the Arria V GX. I attempted to use the Monitor program but I can't get it to work. I suspect this is because the DE2-115 board has two Ethernet jacks that the NiosII c file uses for the test and the Arria V GX only has a single Ethernet jack.
I am still lost on how to send data from the FPGA to the PC and back. I think I have all the modules I need but I can't figure out how to interact with all the modules to do what I want.
This is the Triple-Speed Ethernet Tutorial I went through.
ftp://ftp.intel.com/pub/fpgaup/pub/Intel_Material/17.0/Tutorials/DE2-115/Using_Triple_Speed_Ethernet.pdf
