johny7401
5 years agoRemote update hex file in UFM MAX10 due to UART
I need to update hex file remotely in MAX10 by help of UART. So can I have an access to on_chip_flash IP NOT using HAL software, but due to hardware composed verilog's module?
YuanLi_S_Intel
5 years agoHi Johny,
Yes you can. You need NIOS II in your design to enable that. Please refer to the user guide at link below for more information:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/an/an741.pdf
Thank You.
johny7401
5 years agoPlease write me more detailed what do you mean writing "You need NIOS II in your design to enable that."?
NIOS will be booted from UFM, which has to be upgraded through verilog's module with on_chip_flash IP core using.
