Hi Kelly,
2)You could try the Board Update Portal Example Design which is to bring up an IP address on the board where this design consists of a NIOS II processor:
https://www.intel.com/content/www/us/en/docs/programmable/683553/current/board-update-portal.html
While I am open the example with a 21.3 Quartus Pro. after I Open the IP for upgrade. I got the following error message.
Info: Platform Designer Tip: Please Sync All System Infos before attempting to resolve the following error messages
Error: a10_fpga_bup.sgdma_rx: Component altera_avalon_sgdma 15.1 not found or could not be instantiated
Error: a10_fpga_bup.sgdma_tx: Component altera_avalon_sgdma 15.1 not found or could not be instantiated
Error: a10_fpga_bup.sgdma_tx.m_read: Data width must be of power of two and between 8 and 4096
Error: a10_fpga_bup.sgdma_rx.m_write: Data width must be of power of two and between 8 and 4096
Error: a10_fpga_bup.sgdma_rx.descriptor_read: Data width must be of power of two and between 8 and 4096
Error: a10_fpga_bup.sgdma_tx.descriptor_read: Data width must be of power of two and between 8 and 4096
Error: a10_fpga_bup.sgdma_tx.descriptor_write: Data width must be of power of two and between 8 and 4096
Error: a10_fpga_bup.sgdma_rx.descriptor_write: Data width must be of power of two and between 8 and 4096
Error: a10_fpga_bup.sgdma_tx.csr: Data width must be of power of two and between 8 and 4096
Error: a10_fpga_bup.sgdma_rx.csr: Data width must be of power of two and between 8 and 4096
do I have to install a quartus version like 15.1? it is really painful to keep all the history Quartus version on my PC.
I have learned how to build a Nios II and load it through a cable to the FPGA, what I want to know is how to burn the Nios program to A10 dev kit board flash. I am reading "edh_ed_handbook-683689-666980" chapter 5.
I hope there is an example could show the procedure clear and simple.
to make my question clear, is there a tutorial to show the procedure to load NiosII program to flash and boot it successfully from there.
Thank you,
David
