how to set timing constraints for source synchronous inputs
Thanks for your patience! I think I am close to the answer now.
> for input, external device has their own clock, so we need to use virtual clock for timing constraint.
> for output, for example, FPGA as SPI master to external device. The clock is provided by fpga, so there is no need to use virtual clock.
> for output, for example, FPGA as SPI slave to external device. The clock is provided by external device, so we need to use virtual clock.
> for uart communication, it's asynchronous communication, there is no clock. So we don't need to set any timing contraints.
Please check if my above understanding is right or not. Thanks!
- sstrell4 years ago
You never need to not create timing constraints. For asynchronous interfaces, you'd probably be using false path exceptions.
