Guidance on using an MCU and generic flash as an EPC1QC20 replacement
Hi @JWall40 ,
Since there are no feedback for this thread, I shall set this thread to close pending. If you still need further assistance, you are welcome reopen this thread within 20days or open a new thread, someone will be right with you.
If any answer from the community or Intel Support are helpful, please feel free to give best answer or rate 9/10 survey.
thanks,
Hi, sorry for the delay.
I'd like to use a standard flash memory such as MX25L8006EZUI-12G Macronix | Integrated Circuits (ICs) | DigiKey as the config memory and use a microcontroller to control the configuration process.
2.3.5. Passive Serial Configuration Timing (intel.com) here there is a reference to 'microprocessor as an external host'
I was wondering if there was any example code or an app note on this specifically .
Jack
