KNGanendraMurthy
4 years agoFPGA Enumeration Failure
Hi all,
I am trying to program Intel Arria 10 GX Programmable Acceleration Card through RISC-V CPU(SoC) based Hifive Sifive Unmatched Board via PCI express.I am booting up RISC-V CPU using Ubuntu 2...
JohnT_Altera
4 years agoHi,
I would assume that you are able to detect the FPGA through PCIe in the default OS and facing issue when you implement the DFL Kernel Driver. If this is the case then I could say that you might need to look into the DFL Kernel Driver to see if there is anything that might not be suitable for RISC-V to performed.
KNGanendraMurthy
4 years agoHi,
I have installed OPAE-SDK in RISC-V CPU.I have also installed OPAE-Intel FPGA Device Drivers from sorce packages available in git-hub.I am able to remove the boot-time error by loading OPAE drivers in place of DFL.I am facing error while running 'sudo fpgainfo fme'.I am attaching the screenshot of the error.Kindly suggest solution to the problem
Thanks&Regards
KN Ganendra Murthy
