JWall40
4 years agoConfiguring a FLEX 6000 with an EPCQ config device
I'm looking for a replacement for the EPC1LC20N which I am currently using to configure FLEX 6000 devices.
I see in PDN 1708 that there is no replacement specified for this part.
Is there a w...
- 4 years ago
Flex6K uses a passive serial configuration scheme. If you don't have a programmable controller in your application that can perform the configuration load process, a serial flash in combination with a low pincount microcontroller (e.g. PIC16 or PIC18) should be the solution with lowest cost and board area utilization.
Frank
JWall40
4 years agoPerfect, thanks Frank
