Farabi
1 day agoHello,
Please make sure below connection are implemented:
1- nCONFIG pull up to VCCIO_SDM via 10kOhm resistor
2- nSTATUS pullup to VCCIO_SDM via 10kOhm resistor
3- CONF_DONE is based on your selection of SDM IO pin, default SDM_IO16. If you select other than SDM_IO0 or SDMIO16, you need to connect external 4.7kOhm pulldown resistor to this pin.
regards,
Farabi
