8 years agoRbf jic issue
Hi, I am working with a cyclone IV device EP4CE55 in a project. I programmed jic and the fpga is configuring properly. I programmed rbf file of the same project,FPGA is not configuring.I can s...
8 years agoHi,
--- Quote Start --- MSEL is setting is as follows: MSEL3-0 MSEL2-0 MSEL1-1 and MSEL0-0 --- Quote End --- Refer Table 8-5 for MSEL setting. I think MSEL should be MSEL3-0 MSEL2-0 MSEL1-0 and MSEL0-0 https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/hb/cyclone-iv/cyiv-51008.pdf --- Quote Start --- Is there any difference between active serial and passive serial mode? --- Quote End --- You can refer to the below links and device handbook for more information. https://www.altera.com/support/support-resources/support-centers/devices/cfg-index/cfg-compare.html https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/hb/cyclone-iv/cyiv-51008.pdf Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation)
