12 years agoRapidIO Error Message: Can't Generate Netlist: OpenCore time limited file
Hello, I'm new to the RapidIO Megafunction so this may be a silly question but when I compile my code I get the error message: Can't Generate netlist output... is a OpenCore Plus time-limted fi...
12 years agoI thought Rapid IO was free? I did manage to get around the error message by following:
To avoid this error, disable the EDA simulation tool in your project by opening the Settings dialog box from the Quartus II Assignments menu. Select the category EDA Tool Settings and the subcategory Simulation. On the Simulation page of the Settings dialog box, change the Tool name option to <None>. http://www.altera.com/support/kdb/solutions/rd12202011_654.html?gsa_pos=6&wt.oss_r=1&wt.oss=time-limited file Thanks Galfonz, I will look into purchasing this Megafunction.
