12 years agoRapidIO Error Message: Can't Generate Netlist: OpenCore time limited file
Hello, I'm new to the RapidIO Megafunction so this may be a silly question but when I compile my code I get the error message: Can't Generate netlist output... is a OpenCore Plus time-limted fi...
12 years agoIt's because Quartus doesn't think you've purchased the RapidIO IP. If you did in fact purchase it, follow the licensing instructions. If you haven't purchased the IP, you will need to do so to continue using it.
But I bet you know this already
