amildm
Contributor
4 years agoRapid re-Compilation -> design database is not found
Hi All,
While a Rapid Recompilation I'm receiving the following error:
"Error(20279): Rapid Recompile could not locate a design database from a previous compilation on disk. Perform a successful...
- 4 years ago
2) Yes, exactly.
3) Assignments -> Settings -> Compiler Settings
sstrell
4 years agoFirst, what version of Quartus (Pro I presume) are you using? In recent versions, RR is really only for making changes to Signal Tap.
Also, as the error states, have you enabled Fitter snapshots before performing a full compilation? They are disabled by default (for some reason).
amildm
Contributor
4 years ago1) I'm using Quartus Pro v19.3
2) "In recent versions, RR is really only for making changes to Signal Tap" - what do you mean "only changes in SignalTap"? Adding/removing signals, trigger types, etc?
3) "have you enabled Fitter snapshots before performing a full compilation" - how can I do so?
