14 years ago
RAM mif locations
Where must the mif files for the RAMs reside?
Is is search path dependent?
ex:
set_global_assignment -name SEARCH_PATH mifs_here
    per the global assignments manul it should be this command
    set_global_assignment -name MIF_FILE <value>
    VERILOG_FILE doesn't look right, its probably a MISC_FILE. try adding the file with the GUI and looking at the .qsf
    Would this be correct for adding as a source file?
    set_global_assignment -name VERILOG_FILE ../packetparser/packetparser/pkt_parser/src/mpls/mpls_keylookup_mem_64.mif
    If they are located in the top level directory they will be found automatically, otherwise you can add them just like any other source file to the project.
