17 years agoQuick VHDL question about splitting/joining std_logic_vectors
I have a memory block in my VHDL code and it has output std_logic_vectors that are 32 bit wide. I want to connect those to smaller std_logic_vectors and individual bits of std_logic in some cases. ...
17 years ago --- Quote Start --- Is there a quicker way of doing this --- Quote End --- The only slow thing is, that you have to write a few lines of code. In the sythesized logic, the signals are connected directly. Thus I regard it's the most effective way, usually. To improve readability of your code, ALIAS definitions may be in appropriate way. They are, however limited to a signal type. If the original signal is std_logic_vector, the partial alias expressions have to be std_logic_vector or std_logic. In individual assignments, you are free to cast to a different type, e.g. signed or unsigned.
SIGNAL controlreg : STD_LOGIC_VECTOR (15 downto 0);
ALIAS TriggerMode : STD_LOGIC_VECTOR (2 downto 0) IS controlreg(2 downto 0);
ALIAS TrgMode_nSPI : STD_LOGIC IS controlreg(0);
ALIAS TrgMode_WCtrl : STD_LOGIC IS controlreg(1);
ALIAS TrgMode_WStat : STD_LOGIC IS controlreg(2); Another way is in defining structured data types, which are generally supported by VHDL.
