11 years agoQuestions about Configuring the De5-Net FPGA Board
when i followed the steps in the "de5net_network_opencl_manual.pdf", i got the following problems: 1.in "test ‘aocl flash’ command" section, after i finished the clock setting and tried to use ...
11 years agoI should probably post a patch file at some point, but it is the __devinit, __devexit and other such macros that are causing issues as they are not defined in the altera lib and therefore I assume they are defined in the older kernel headers. Remove all these and try again.
Cheers B
