11 years agoQuestions about Configuring the De5-Net FPGA Board
when i followed the steps in the "de5net_network_opencl_manual.pdf", i got the following problems: 1.in "test ‘aocl flash’ command" section, after i finished the clock setting and tried to use ...
11 years ago --- Quote Start --- Hi Chris, I didn't solve this problem yet. After you downgrade the kernel, did you install it successfully? I use the 14.04 of Ubuntu. Should I downgrade it into 12.0 of Ubuntu? Thanks Jiawen --- Quote End --- I am not using Ubuntu for the fpga board. But you can check the kernel version to decide which version to roll back to. The kernel should include a set of macros (such as __devint).
