11 years agoQuestions about Configuring the De5-Net FPGA Board
when i followed the steps in the "de5net_network_opencl_manual.pdf", i got the following problems: 1.in "test ‘aocl flash’ command" section, after i finished the clock setting and tried to use ...
11 years agoHi Chris,
I didn't solve this problem yet. After you downgrade the kernel, did you install it successfully? I use the 14.04 of Ubuntu. Should I downgrade it into 12.0 of Ubuntu? Thanks Jiawen --- Quote Start --- The kernel is too new. Downgrading your kernel will solve the errors shown above. --- Quote End ---
