10 years ago
Question regarding VCCIO of arria V SX series
Hi ,
I am planning to use 5ASXMB3G4F40I5N in my current project.
I am using Bank 3A and 3C for 3.3V LVCMOS signals.
so my question is can i use bank 3D for LVDS signals.
if i can use it then what will be the VCCPD for group ( 3A,3B,3C,3D )?
thanks and regards
mahima satsangi
    In the handbook, I hvn't found anything about using different VCCIOs within same group (3A,3B,3C,3D).
    .pin file is not getting generated. I believe fitter is not generating that report due to following error.
    Error " Error (169215): VCCIO assignment (2.5V) on I/O Bank 3D cannot be applied
    Error (169325): VCCPD3 cannot use 2.5V because it is using 3.3V
    Info (169323): VCCIO 2.5V requires VCCPD 2.5V.
    I have made the following assignments:
    Bank VCCIO
    3A 3.3V
    3B 2.5V
    3C 3.3V
    3D 2.5V
    Thanks and regards
    Mahima Satsangi
    Use Quartus to answer this question for you. Put a small project together for your chosen part. Constrain the I/O as you require, run it through the tools and look at the generated .pin file. It will tell you what to voltage to connect to the VCCPD pins.
    Cheers,
    Alex
