11 years agoQuestion regarding loading the SRAM with .ram files and additional .sof file
Greetings, In one of our course project, we are to design a small processor which requires instructions to be fetched from the SRAM memory. The procedure given is as follows: 1. We open th...
11 years agoHello A_X_H75,
Thanks for your reply! I understand that there is probably nothing special about writing the data multiple times. However, I do want to point out that all of my classmates are able to consistently have the memory not corrupted after doing this. I was thinking of programming instruction into FLASH, but then I realize the length of word is different from what we wanted. Of course we can change the load cycle to load more for that but that would be a more complicated work. What I am hoping for is perhaps a way to load the processor.sof file "above" a specific location so that my instructions, which starts at 0x0000 to somewhere pretty much less than 0x0100 may not be affected. Thanks again for your reply!
