12 years agoQuestion regarding CyclonV ALMs
I am new to Altera FPGAs, so I did some study on the internal design reading the following document: http://www.altera.com/literature/hb/cyclone-v/cv_52001.pdf What confuses me a bit, are the ALMs - so it would be really great to get some answers:- Is an ALM a physical structure on-chip, whereas "logic elements" (LE) is basically only a logical equivalent (to be able to compare between different families, vendors, ..)?
- The document states an ALM can have a single function with up to 6 inputs, but up to 8 inputs are connected to boolean logic. Does this mean if I would like to use an ALM for boolean logic only, I can use all 8 inputs?
- to compare 256x8-bit integer values against a single 8-bit value (so 2k "active" bits)
- Later perform a 15x15 box aggregation on 8-bit values
1 Reply
The ALM is a physical structure on-chip. It can be used in several different modes.
In 6-LUT mode, it can compute any function of 6 input bits. So why does it have 8 inputs? The ALM can also be split into two smaller units. You can get two completely independent 4-input functions from one ALM. (You can also get two 5-input functions, providing that the two 5-input functions share at least two inputs in common.) In this mode, each half-ALM can implement the same functions as a Cyclone IV LE, so (roughly speaking) 1 ALM = 2 LEs. When it's used in an adder (yet another mode), each ALM will produce 2 bits of the result. For simple functions - add, compare etc you'll need 1 4-LUT per bit. Depending on how you're handling overflow, an 8-bit add may require a 9-bit output, which would be 5 ALMs. A comparison is similar.
