12 years agoQuestion regarding CyclonV ALMs
Hi, I am new to Altera FPGAs, so I did some study on the internal design reading the following document: http://www.altera.com/literature/hb/cyclone-v/cv_52001.pdf What confuses me a bit, ...
12 years agoThe ALM is a physical structure on-chip. It can be used in several different modes.
In 6-LUT mode, it can compute any function of 6 input bits. So why does it have 8 inputs? The ALM can also be split into two smaller units. You can get two completely independent 4-input functions from one ALM. (You can also get two 5-input functions, providing that the two 5-input functions share at least two inputs in common.) In this mode, each half-ALM can implement the same functions as a Cyclone IV LE, so (roughly speaking) 1 ALM = 2 LEs. When it's used in an adder (yet another mode), each ALM will produce 2 bits of the result. For simple functions - add, compare etc you'll need 1 4-LUT per bit. Depending on how you're handling overflow, an 8-bit add may require a 9-bit output, which would be 5 ALMs. A comparison is similar.
