13 years agoQuestion about the FPGA 10/100 Ethernet (FPGA)
I want to get some information about how to support the "10/100 Ethernet (FPGA)".
But I do not searched enough information except below: 10/100 Ethernet (FPGA) The development board supports an RJ-45 10/100 base-T Ethernet using an external Renesas uPD60620 PHY. This PHY supports EtherCAT, Ethernet IRT and DLR features using 3rd party MAC IP. The PHY-to-MAC interface employs MII connection using four data lines at 25 Mbps each for a connection speed of 100 Mbps. And I have some questions as below:- What is the MAC of the 10/100 Ethernet (FPGA)?
- These 2 ports used for EtherCAT(mainly? Only?) or normal TCP/IP?
- Is there some app/driver/test that shows how to use it?
--- Quote Start --- I want to get some information about how to support the "10/100 Ethernet (FPGA)". But I do not searched enough information except below: 10/100 Ethernet (FPGA) The development board supports an RJ-45 10/100 base-T Ethernet using an external Renesas uPD60620 PHY. This PHY supports EtherCAT, Ethernet IRT and DLR features using 3rd party MAC IP. The PHY-to-MAC interface employs MII connection using four data lines at 25 Mbps each for a connection speed of 100 Mbps. And I have some questions as below:- What is the MAC of the 10/100 Ethernet (FPGA)?
Thanks for your help.
OK, there is a problem with my link insertion. Now corrected. However you can always find the latest kit installation package at: http://www.altera.com/products/devkits/altera/kit-cyclone-v-soc.html On the FPGA portion the usual TSE_MAC integrated into the QSys design. I suggest to see the TSE MAC and Reneseas chip documentations for further details. Regards, ZS.V. - Altera_Forum
Hi, there's no such file in the Ftp SITE, could you help to check if it is put there?
Also, is there some document that described the FPGA MAC? - Altera_Forum
