17 years agoquestion about sdram on nios II
After I finished my project and built it ,there is no any error or warning.But when I run my C project,it said : "Using cable "ByteBlasterII [LPT1]", device 1, instance 0x00 Processor is already...
15 years agoi wrote a simple module and i instantiate dual port RAM in the same module.then i run my module through niosii and also i use both onchip memory and sdram controller,i get this error message
Info: Your component is not based on HDL. An instance of this component will export reversed-direction signals to connect to an external module. Warning: The component has no signals. please help me
