14 years agoQuestion about PLL's output jitter
I found below comment from device's datasheet: "250 ps for >= 100 MHz coutclk. 25 mUI for <100 MHz outclk" Here, how to understand "mUI"?
14 years ago --- Quote Start --- Altera said that the PLL's output will phase align with the input when the PLL work on normal mode. But i want to know how aligned between the output and input? What's the different of the output and the input's phase? --- Quote End --- I will assume zero unless proved otherwise. --- Quote Start --- Another question is how to understand the spec of toutjtter parameter in the handbook as attached file? This jitter is of the PLL's external (external of the FPGA) output or internal output? --- Quote End --- I think one refers to pll output clock (internal) and the other refers to that at io.
