12 years agoQuestion about optimizing a VHDL based system.
Hi all, I finally managed to have my system to work as I expected but I am quite dissapointed with the too high number of LEs required by the entire project. I wanted to know if you had ...
12 years agoHave a look at the fitter compile report > Resource Section > Resource Utilization by Entity. There you can find out if one of your components stands out in resource usage or if it's a problem spread around your design.
Large buses can lead to heavy resource usage, and usually 512-bit buses shouldn't be necessary if you don't need a huge data bandwidth. That said if all your logic operates on 512 bit words, serializing and deserializing them in 32-bit buses to interconnect several components together probably won't help much.
