15 years agoQuestion about Monitor
Hello, is it possible to synthesize the "monitors" on the altera fpgas'. There are Monitor IPs such as Avalon MM Monitor. Can I synthesize such "Monitors"?
15 years ago --- Quote Start --- When I click on edit how do I configure the IP to be root port or end point port. [in qsys] --- Quote End --- Sorry, I have not used this IP. The IP users guide and examples should tell you how to do it. The PCIe webinar indicated the component could be configured for both root complex and end point, so the feature exists. Perhaps try this webinar: http://www.altera.com/education/training/courses/opci1010 Here's the IP page: http://www.altera.com/products/ip/iup/pci-express/m-alt-pcie8.html Did you happen to read this: --- Quote Start --- The PCI Express Compiler includes an endpoint testbench that incorporates a simple root-port bus functional model (BFM) and multiple endpoint example designs. You can use these example designs, available in clear-text source-code (VHDL) and Verilog (HDL), as references to kick-start your design, while the simple root-port BFM is geared to provide an "out of the box" PCI Express experience. --- Quote End --- The PCIe compiler includes a PCIe root complex BFM ... so technically you could have used that in your design. The PCIe hard-IP page: http://www.altera.com/technology/high_speed/protocols/pcie-hard-ip/pro-hard-ip.html has these comments --- Quote Start --- Dual mode to support both endpoint (legacy and native) and root port functionality --- Quote End --- You need to read the documentation. http://www.altera.com/literature/ug/ug_pci_express.pdf Chapter 15 has testbench examples for both root and endpoints. Cheers, Dave
