15 years agoQuestion about Monitor
Hello, is it possible to synthesize the "monitors" on the altera fpgas'. There are Monitor IPs such as Avalon MM Monitor. Can I synthesize such "Monitors"?
15 years ago --- Quote Start --- I am talking about the outputs. The pcie_core_clock and pcie_core_reset are the outputs form the PCIe IP core. --- Quote End --- Are they outputs from the 'root complex' (your BFM design) or from the 'end-point device' (your FPGA design). The reference clock from the root complex might be required by the end-point device if the two are to be synchronous ... or that same connection could be via a common clock in your testbench. I would look at Altera's examples to see what they do. This webcast implies that Altera's examples have a PCIe BFM http://www.altera.com/education/webcasts/all/source-files/wc-2011-pcie-technology-design-fpga/player.html Earlier you implied that Altera did not. Setting up the testbench I have described is a good exercise in learning the tools. Once you've got it working, you should go back and check out the newest Altera PCIe examples ... perhaps they have improved. Cheers, Dave
