15 years agoQuestion about Monitor
Hello, is it possible to synthesize the "monitors" on the altera fpgas'. There are Monitor IPs such as Avalon MM Monitor. Can I synthesize such "Monitors"?
15 years ago --- Quote Start --- Some clarifications before I get to conduits: When I create system that can be synthesized on an FPGA the components of my system is glued by the Avalon interfaces right? --- Quote End --- In SOPC Builder or Qsys, when you click connections between components, you are making Avalon connections; either MM or ST. --- Quote Start --- This interface is also called as System Interconnect Fabric right and is made up of Avalon Bus, right? --- Quote End --- Yeah, pretty much. --- Quote Start --- These conduits kick in only when the signals are going out of FPGA or if the signals are entering the FPGA right? --- Quote End --- Entering or leaving the SOPC system. You could connect them to external signals, or you could loop them back into the SOPC system, eg., control signals from a PIO component might loop back into the system via a different conduit to enable/disable another component. --- Quote Start --- Now coming to what you said, If I have a PCI bus then, a conduit shows up between the PCI bus external to the FPGA and Avalon interface within the FPGA right? --- Quote End --- Yes. All the PCI signals would be marked as conduit signals. --- Quote Start --- When conduits show up in Qsys what should I do with them? leave them alone? since they are connected to outside of FPGA. --- Quote End --- I would guess you leave them unconnected. I have not used Qsys much yet. I'm not sure why the conduits show up in the GUI. Perhaps someone else can comment. Cheers, Dave
