15 years agoQuestion about Monitor
Hello, is it possible to synthesize the "monitors" on the altera fpgas'. There are Monitor IPs such as Avalon MM Monitor. Can I synthesize such "Monitors"?
15 years agoHello Dave,
I have connected the custom component to "Onchip RAM" and I am able to wire data to the memory. [I first Generate the simulation files in Verilog and attach only the Clock and Reset BFMs. Then using the test bench I write data to the ram using some tasks and observe the result in the memory viewer window] The .tcl file of the component is working fine. What I don't understand is the missing start/end point in the error message ? Thanks, E=mc2
