19 years agoQuestion about LVDS!
I am designing a board which contains two cyclon III FPGA(EP3C120). And I want to use LVDS as the communication interface between the two chips and I use the megacore, ALTLVDS. My problem is: how many pairs of differential siganl lines should be used to achieve 1GByte/s speed in one direction? Thanks!
1 Reply
Refering to the Cyclone III Users Guide.
Volume 1 - Section II - Chapter 8 - page 8-1 (March 2007) LVDS receive at 875 Mbits / sec (all sides) LVDS transmit at 840 Mbis / sec on left and right sides. The limiting factor them is the transmiter speed of 840 Mbits / sec. If you derate this to 800 Mbits / sec. it would take 8 of them to get 8 MBytes / sec. 10 of them would give you 1 GBytes / sec. (9 will not get you there.) That is the minimum. I would make life simple if I had the IO and go with 16 @ 500 Mbits /sec if I had the I/O as this might make it easier to group and ungroup the signals internally. You call. Avatar
