15 years ago
Question about License?
Hi :):),
My problem is when i try to recompile the project given by Stratix IV "board_update_portal" with a just change in PLL ( increase the frequency).
I constate that the changement not taken it consideration, As i mentionned in
http://www.alteraforum.com/forum/showthread.php?p=126717&posted=1#post126717.
My question Now this problem dues to the License or NO?
I note that i use a evaluation quartus 9.1.
    does the modified date on the resulting .sof file change, and does it reflect the actual compilation time?
    --- Quote Start ---
    If the design is using some opencore IP for which you don't have the license, it will create a time limited FPGA image. If your project is called myfpga, the resulting programming file will be called myfpga_time_limited.sof instead of just myfpga.sof.
    --- Quote End ---
    Thanks for you reply Daixiwen
    In my SOPC there are some IP core as CPU, PLL, ...etc.
    As i said: i use a evaluation version. On the resulting program i don't obtained _time_limited.sof.:(
