15 years agoQuestion about License?
Hi :):), My problem is when i try to recompile the project given by Stratix IV "board_update_portal" with a just change in PLL ( increase the frequency). I constate that the changement not ta...
15 years ago --- Quote Start --- If the design is using some opencore IP for which you don't have the license, it will create a time limited FPGA image. If your project is called myfpga, the resulting programming file will be called myfpga_time_limited.sof instead of just myfpga.sof. --- Quote End --- Thanks for you reply Daixiwen In my SOPC there are some IP core as CPU, PLL, ...etc. As i said: i use a evaluation version. On the resulting program i don't obtained _time_limited.sof.:(
