Question about Autonomous Mode Configuration
- 7 years agoHi, Please refer to chapter 4.2 of https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_a10_pcie_avst.pdf document. It will mention which PCIe hard IP will be able to meet the 100ms wake up time. Based on that location then you will need to either mapped it to the pin planner or pin-out file for the exact pin to be connected to the PCIe host.
- xytech7 years ago
Contributor
Hi John, Thanks for reply.
I do searched through and compare ug_a10_pcie_avst.pdf and ug_a10_pcie_avmm.pdf (the one you mentioned), both docs are nearly the same. first doc on section 12.2, and second doc on section 14.2.
Thanks for point out that total bitstream size will not change. However, what I need to konw is the individual size of each part when use AM, that is, what's the size of periphery image? and what's the size of core image. Two
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_a10_pcie_avmm.pdf
Furthermore, could you please take a look at my second question? Copied here.
Both docs mentioned “only the bottom Hard IP for PCI Express on either side can satisfy the 100 ms PCIe wake up time requirement.” What is the exact context of this “BOTTM” means? Under TOP VIEW or Bottom VIEW? on what position should the pin A1 be? As you know, sometimes “BOTTOM side” could become “TOP side” if chips are spined or flipped on PCB layout……
Thanks again.
