obruendl's avatar
obruendl
8 months ago
Questa Starter license missing FEATURE/INCREMENT lines”
I just tried to generate a new Questa Starter license through the Self Licensing Center but the license file I got is corrupted (it does not contain the "increment" statement and hence it actually does not contain a license).
I tried generating the license several times but I always got such a corrputed file. You can find the corrupted file attached.
The problems seems to apply for Questa Starter only. Other free features (e.g. Agilex-5 support) could be licensed correctly (contained an increment statement).
How can I generate a Questa Starter License?
I am maintaining the Open Logic FPGA Standard Library - also officially supporting Altera. So I'd hope there should be some mutual interest of fixing the issue.
  • Joel_Aaron_Seely's avatar
    Joel_Aaron_Seely
    Could you try again and let me know if you get the same results?  I just tried generating a Quartus evaluation license (it includes a QuestaSim Starter license) through the SSLC and got a valid license back.  I'm trying to determine if this is a glitch or we need to dig deeper.  Thanks.  -Joel-
    • obruendl's avatar
      obruendl
      Yesterday I tried it 4 times - and all generated licenses were consistently invalid.
      I tried again today, now it works. So my problems is fixed but probably you want to check what lead to the glitch.
        Joel_Aaron_Seely
        Thanks for checking.  Yes, we're looking into what might have been the root cause of the issue.  But I'm glad to know you're no longer stuck.
