12 years agoquartus/Nios 13.1 make mem_init_generate error 255
I have a project created in nios 13.1 that I am trying to create a hex file for. From C:\altera\13.1\nios2eds I load the Nios II Command Shell.bat which loads the command shell Next i nav...
12 years agoI tried to set the QUARTUS_ROOTDIR via the "Nios II Command Shell.bat" file it gave the error
C:\altera\13.1\nios2eds>"Nios II Command Shell.bat" QUARTUS_ROOTDIR_OVERRIDE="C: \altera\13.1\quartus\quartus" C:/altera/13.1/nios2eds/nios2_command_shell.sh: line 175: exec: QUARTUS_ROOTDIR_ OVERRIDE=C:\altera\13.1\quartus\quartus: not found I checked the folder and saw that it does not have a quartus folder within C:\altera\13.1\quartus --------------------------------------------------------------------------- Update, By deleting bin folder contents from C:\altera\13.1\nios2eds\bin and replacing it with the contents found in C:\altera\13.0sp1\nios2eds\bin I was able to get everything to work.
