12 years agoquartus/Nios 13.1 make mem_init_generate error 255
I have a project created in nios 13.1 that I am trying to create a hex file for. From C:\altera\13.1\nios2eds I load the Nios II Command Shell.bat which loads the command shell Next i nav...
12 years agoRan into the same problem on linux. My normal shell environment was missing the QUARTUS_ROOTDIR variable. Setting it to C:\altera\13.1\quartus\quartus should get you going.
