11 years agoQuartus v14.0 Altera_PLL IP targeting Cyclone V (5CEFA7) does not lock
board - Has a 5CEFA7F23I7 (Cyclone V E A7). The analog PLL power supply pins (6 VCCA_FPLL pins) have a common 2.5V rail, decoupled with approx. 64uF, split across 16 or so caps. The 2.5V is driv...
11 years ago --- Quote Start --- approx. 64uF, split across 16 or so caps. --- Quote End --- Approx. 4uF per cap - what are these caps? Do you have any low value, low ESR ceramic caps as well? Cyclone V devices, particularly the PLL rails, won't tolerate much noise. A LDO will help but only if it has sufficient decoupling close to the appropriate FPGA power pins. Have you tried any other PLL configurations? Reduce the multiplier. Finally, in line with comments from lars, have you followed all the Cyclone V connection guidelines? See cyclone® v device family pin connection guidelines (https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/dp/cyclone-v/pcg-01014.pdf). An incorrect or missing RREF_TL resistor is a very likely candidate. Cheers, Alex
