10 years agoQuartus result not making sense, multicycle resulted in large violations?
my design has wide adders, 42 bit adders. with 10ns clock period, it has -10ns slack. I change the adder path to be multicycle path x2. with data required time being 20ns, the new Quartus compile...
10 years agoThank you so much for taking the time to reply to my question.
I tried your suggest and added the MC hold constraints. after that the design became unroutable, or cannot fit. if I remove the MC constraints, it can compile and finish; is it possible that the MC constraints are not supplied in compile time but only provided to it at timequest time?
