Quartus Programmer (quartus_pgmw.exe) 15.1 build 185 Failure to Function on First Attempt
From the screenshot, you do not tick on the "verify" features but the Quartus still performed verify. May I know if you have another system to try and see if you are facing the same issue?
- scott2j65 years ago
Hey John,
I think I was able to figure it out.... well sort of.
Under the Device Settings, I had the option 'Verify Protect' enabled.
After disabling it, I have been able to program successfully every time.
I have tried gathering more information about this setting, but I haven't found much to enlighten me on why this setting was causing my issues.
Do you happen to know anything about this?
Thanks for your time - scott2j65 years ago
Hey John,
I have actually tried this on at least 4 other pc's (2 development computers with full Quartus Installed, 2 quality control computers with bare minimum install) and its behaved the same way.
Is there perhaps a setting in the Quartus 2 application that would change how the programmer interacts with the .pof file?
