8 years agoQuartus prime pro 18 upgrade error
Hi, please see the original project file comes from intel altera cyclone 10 gx devleopment kit called qts_fmc.zip at the attachment file section. I am using the project comes with Cyclon...
8 years ago --- Quote Start --- Can you open each IP in the IP parameter editor (open each IP's .ip file)? You should try doing this and just regenerate each one, even if it's saying you don't have to upgrade it. --- Quote End --- Hi, No, even with this approach, I am getting error messages. We have a upgrade problem by using: 1- The design comes with Cyclone 10 GX dev kit 2- Software Quartus Prime Pro from 17.1 to 18.0 question : do you think the reference design owner may have a comment on this? unless quartus 18.0 has a bug on this?
