app_engineer
5 years agoQuartus PGM Error help (Expected JTAG ID code 0x032250DD for device 1, but found JTAG ID code 0x020A
Hello, I am using quartus to program a Stratix10 board. The board version is 1sg280hu2f50e2vgs1@1.
After programming the bitfile we are getting an error message in quartus pgm with log:
31:Er...
YuanLi_S_Intel
5 years agoHi,
Just would like to check, which bitstream are you using to programming stratix device? I would recommend you to delete the 2 devices on programmer, then add the bitstream that you want to program into the programmer and then program it. Also, you will need to change the TCK frequency to 6MHz.
Thank You.
