Quartus PGM Error help (Expected JTAG ID code 0x032250DD for device 1, but found JTAG ID code 0x020A
I am using a SOF file to program the board.
This is the output of my jtagconfig command on the board:
/remote/sbg_toolkits/Altera/quartus_19_4_pro_linux/quartus/bin/jtagconfig
1) USB-BlasterII [1-2.3]
020A40DD 5M(1270ZF324|2210Z)/EPM2210
C32250DD 1SG280HH1(.|S3|AS)/1SG280HH2/..
Is the 020A40DD Jtag ID correct for the Stratix10 GX board?
Hi Please partially disregard some detail on previous reply:
About last question, I seen late two device appear on jtag chain, is the right one selected?
Stratix is the device 2 not the device 1.
So you assigned stratix file to CPLD EPM2210 or to Stratix? can you post a screenshot of programmer in actual config
and then after pressing auto detect button?
- app_engineer5 years ago
When I bring up the programmer this is what I see:And if I select HH1 device here is the chain:
- RRomano0015 years ago
Contributor
Hello, exactly as from jtagd stratix device is chained as device 2, right one on my previous post must sound as correct one.
On graphic programmer view sound as "right side <-(one)" you are trying program the left device with file built for stratix.
I don't own this board but looking inside manual instruct use command line programmer directing file to device 1 (Left on graphic version). This seem wrong and generate the error you experienced.
Double click on right IC image and add file or click on file relative to Stratix, leave CPLD 2210 unselected.
If you are using command line, board manual use device 1 in chain but on your board this is CPLD not stratix.
Try change chain device from 1 to 2 and retry.
And last but not least, never seen as reply, which file are you using for?
I reconnected my previous Stratix10 board which has power issues and was able to notice that the JTAG ID code is different.The board that I am trying to debug in this thread has the info:
Info (213045): Using programming cable "USB-BlasterII [1-2.3]"
C32250DD 1SG280HH1(.|S3|AS)/1SG280HH2/..V/S the old board which has the info:
032250DD 1SG280HH(1S1|2S1|3S1)/..
