Quartus license not recognized by Quartus
Based on my understanding, a time_limited.sof is generated due to license don’t have the Nios II Processor (6AF7 00A2) future. It’s needed a valid license of Nios II to run the build.
can purchase thru distributor. Please find the contact for our sales and distributor near you from link below:
https://www.intel.com/content/www/us/en/partner/where-to-buy/overview.html
Alternative you could apply an Intel 90-Day Evaluation License use with Quartus Pro/Standard. Login to Intel® FPGA Self Service Licensing Center and request the Quartus evaluation free license here https://licensing.intel.com/
1) Go to Sign up for Evaluation or Free licenses
2) Select Intel® FPGA EVALUATION-LIC
3) # of Seats is always 1
4) Check the T&C box
5) Add the required options
6) Click Get License button
The license will be sent to email that you register with
- T24 years ago
The Nios II license was purchased at the same time as the Quartus license:
When I generated the license I had both licenses selected. Is there another way to get both licenses in the one generated license file?
- T24 years ago
I solved the issue. In the active maintenance license page, even though the Nios license showed the correct primary computer, it was not being generated. I edited the license the Nios license settings primary computer setting to none, then back to my active computer; saved and generated a new license file. Now Quartus generates a .sof that is not time limited.
