12 years agoQuartus II 13.1 CPLD device support
i am attempting to program an EMP2178AETC100-10N (MAX7000 CPLD family) using Quartus II 13.1 and an USB Blaster. It appears that this device is not supported with Quartus II and USB Blaster, but rat...
12 years agoA small consolation is that you can;
1. Use VirtualBox to install old versions of Quartus (inside old OSes if necessary) 2. "Share" your local hard drive, so that you can access source files without having to copy them to the VM 3. "Capture" a USB-Blaster if you want to download and or debug from within the VM. Though it might be possible to download and run something like SignalTap II with a newer version of Quartus ... I have not tested this option. I've been using this scheme to deal with FLEX10K designs (Quartus 9.0sp2), so I guess I'll just add a few more VMs ... :) Cheers, Dave
