12 years agoQuartus II 13.1 CPLD device support
i am attempting to program an EMP2178AETC100-10N (MAX7000 CPLD family) using Quartus II 13.1 and an USB Blaster. It appears that this device is not supported with Quartus II and USB Blaster, but rat...
12 years agoYes. Altera has started dropping legacy family support from the latest versions of Quartus.
If there are any Altera Software managers viewing this: I understand why you want to remove the devices from the software for download size. But a MUCH better solution is to have Quartus automatically download the specific device files from a repository when you want to use them, instead of removing them completely. You are creating a nightmare for companies having to deal with legacy and new development. I would much rather have a 5 minute penalty the first time I use a new device instead of downloading multiple GB of devices I'll never use, then having to maintain multiple versions of Quartus to keep some legacy devices supported. Don't remove a device from support, until the devices can no longer be purchased. Having version of the software for specific families is also not a good idea. Why should I have to install 2 versions Quartus 13.1 just because I want to play with some Arria 10's? Much better, have the Arria 10 listed, and if I select it for a design, it downloads the specific parts device files. This would also fix the issue where your quartus and devices versions don't match. IE when installing a Service Patch, often the devices are updated as well. But may not get installed. This causes issues as well. My mini rant. Pete Pete
