14 years agoQuartus doesnt recognize my FSM as a FSM
Hello guys i have a "problem", i can't see my FSM as a FSM inside quartus state machine view or RTL viewer or whatever, is this a problem? I use two processes, one is combinational and the other i...
14 years agoI always use one process state machines as I find they are easier to write. They are perfectly recognised as such by Quartus, even if I don't follow strictly their recommended style (http://www.altera.com/literature/hb/qts/qts_qii51007.pdf).
Your problem could come from the fact that you register a whole bunch of signals in the first process and have all your signals retain their previous value in the second process. I hope that Quartus is smart enough not to generate latches from your second process description.
